Knots is looping in running-erroring-restarting
Please can somebody tell me what to do? Knots (and also all the other programs are starting, running, erroring in a loop)
Here is the loop of the log info on Knots:
2025-06-25T08:28:01Z Shutdown: done
2025-06-25T10:28:17+02:00 Error updating blockchain info: error: timeout on transient error: Could not connect to the server 127.0.0.1:8332
2025-06-25T10:28:17+02:00 Make sure the bitcoind server is running and that you are connecting to the correct RPC port.
2025-06-25T10:28:17+02:00 Use “bitcoin-cli -help” for more info.
2025-06-25T10:28:17+02:00 Error updating network info: error: timeout on transient error: Could not connect to the server 127.0.0.1:8332
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Bitcoin Knots version v28.1.0 (release build)
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z parameter interaction: -externalip set → setting -discover=0
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z ParameterInteraction: parameter interaction: -walletimplicitsegwit=0 → setting -addresstype=legacy
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Script verification uses 15 additional threads
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using the ‘sse4(1way)’ SHA256 implementation
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Feeding 37211 bytes of environment data into RNG
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using RdSeed as an additional entropy source
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using RdRand as an additional entropy source
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Default data directory /root/.bitcoin
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using data directory /root/.bitcoin
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file: /root/.bitcoin/bitcoin.conf
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z R/W Config file: /root/.bitcoin/bitcoin_rw.conf (not found, skipping)
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: acceptnonstddatacarrier=“0”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: avoidpartialspends=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: bind=“0.0.0.0:8333”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: blockfilterindex=“basic”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: blockmaxsize=“3985000”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: blockmaxweight=“3985000”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: blocknotify=“curl -s -m5 http://datum.embassy:7152/NOTIFY”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: bytespersigop=“20”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: bytespersigopstrict=“20”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: datacarrier=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: datacarriercost=“2”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: datacarriersize=“42”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: deprecatedrpc=“create_bdb”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: disablewallet=“0”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: discardfee=“0.0001”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: dustrelayfee=“0.00003”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: limitancestorcount=“25”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: limitancestorsize=“101”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: limitdescendantcount=“25”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: limitdescendantsize=“101”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: listen=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: maxmempool=“300”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: maxscriptsize=“1650”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: mempoolexpiry=“336”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: mempoolfullrbf=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: minrelaytxfee=“0.00001”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: permitbaremultisig=“0”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: permitbarepubkey=“0”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: persistmempool=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rejectparasites=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rejecttokens=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rpcallowip=“0.0.0.0/0”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rpcbind=“0.0.0.0:8332”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rpcpassword=****
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rpcservertimeout=“30”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rpcthreads=“16”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rpcuser=****
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: rpcworkqueue=“128”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: txindex=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: v2transport=“1”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: whitelist=“172.18.0.0/16”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: zmqpubhashblock=“tcp://0.0.0.0:28332”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: zmqpubhashtx=“tcp://0.0.0.0:28333”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: zmqpubrawblock=“tcp://0.0.0.0:28332”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: zmqpubrawtx=“tcp://0.0.0.0:28333”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config file arg: zmqpubsequence=“tcp://0.0.0.0:28333”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Command-line arg: conf=“/root/.bitcoin/bitcoin.conf”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Command-line arg: datadir=“/root/.bitcoin”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Command-line arg: deprecatedrpc=“warnings”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Command-line arg: externalip=“lizsra5zhxuxdpxectezh47akwwfpqqm6izow5fl2lc6fdplwuorthid.onion”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Command-line arg: onion=“172.18.0.1:9050”
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using at most 125 automatic connections (1048576 file descriptors available)
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z scheduler thread start
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Binding RPC on address 0.0.0.0 port 8332
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z WARNING: the RPC server is not safe to expose to untrusted networks such as the public internet
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Config options rpcuser and rpcpassword will soon be deprecated. Locally-run instances may remove rpcuser to use cookie-based auth, or may be replaced with rpcauth. Please see share/rpcauth for rpcauth auth generation.
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Starting HTTP server with 16 worker threads
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using wallet directory /root/.bitcoin
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z init message: Verifying wallet(s)…
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using /16 prefix for IP bucketing
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z init message: Loading P2P addresses…
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Loaded 68292 addresses from peers.dat 193ms
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z init message: Loading banlist…
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z SetNetworkActive: true
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z AddLocal(lizsra5zhxuxdpxectezh47akwwfpqqm6izow5fl2lc6fdplwuorthid.onion:8333,4)
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Cache configuration:
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z * Using 2.0 MiB for block index database
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z * Using 56.0 MiB for transaction index database
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z * Using 49.0 MiB for basic block filter index database
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z * Using 8.0 MiB for chain state database
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z * Flushing caches if available system memory drops below 10 MiB
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z * Using 335.0 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using obfuscation key for blocksdir *.dat files (/root/.bitcoin/blocks): ‘9adee7afe9a0167b’
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using 16 MiB out of 16 MiB requested for signature cache, able to store 524288 elements
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using 16 MiB out of 16 MiB requested for script execution cache, able to store 524288 elements
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z init message: Loading block index…
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Assuming ancestors of block 000000000000000000006e926737e6a349f7581525ad36e743dfe5f4bc3abbb7 have valid signatures.
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Setting nMinimumChainWork=0000000000000000000000000000000000000000b08ea5865bede3101629fa0e
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Opening LevelDB in /root/.bitcoin/blocks/index
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Opened LevelDB successfully
2025-06-25T10:28:17+02:00 2025-06-25T08:28:17Z Using obfuscation key for /root/.bitcoin/blocks/index: 0000000000000000
2025-06-25T10:28:21+02:00 2025-06-25T08:28:21Z LoadBlockIndexDB: last block file = 4998
2025-06-25T10:28:21+02:00 2025-06-25T08:28:21Z LoadBlockIndexDB: last block file info: CBlockFileInfo(blocks=81, size=120060404, heights=902447…902527, time=2025-06-23…2025-06-24)
2025-06-25T10:28:21+02:00 2025-06-25T08:28:21Z Checking all blk files are present…
2025-06-25T10:28:21+02:00 2025-06-25T08:28:21Z Initializing chainstate Chainstate [ibd] @ height -1 (null)
2025-06-25T10:28:21+02:00 2025-06-25T08:28:21Z Opening LevelDB in /root/.bitcoin/chainstate
2025-06-25T10:28:21+02:00 2025-06-25T08:28:21Z Opened LevelDB successfully
2025-06-25T10:28:21+02:00 2025-06-25T08:28:21Z Using obfuscation key for /root/.bitcoin/chainstate: 1033cbf22294293f
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Loaded best chain: hashBestChain=00000000000000000000b7036470be554afa3e9eb67a954866df2eb6c7aef260 height=901561 date=2025-06-16T21:30:26Z progress=0.995934
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z init message: Verifying blocks…
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verifying last 6 blocks at level 3
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verification progress: 0%
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verification progress: 16%
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verification progress: 33%
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verification progress: 50%
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verification progress: 66%
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verification progress: 83%
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verification progress: 99%
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Verification: No coin database inconsistencies in last 6 blocks (14720 transactions)
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z block index 4795ms
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Opening LevelDB in /root/.bitcoin/indexes/txindex
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Opened LevelDB successfully
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Using obfuscation key for /root/.bitcoin/indexes/txindex: 0000000000000000
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Opening LevelDB in /root/.bitcoin/indexes/blockfilter/basic/db
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Using obfuscation key for /root/.bitcoin/indexes/blockfilter/basic/db: 0000000000000000
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z [error] basic block filter index: best block of the index not found. Please rebuild the index.
2025-06-25T10:28:22+02:00 Error: basic block filter index: best block of the index not found. Please rebuild the index.
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Shutdown: In progress…
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z scheduler thread exit
2025-06-25T10:28:22+02:00 2025-06-25T08:28:22Z Flushed fee estimates to fee_estimates.dat.
2025-06-25T10:28:23+02:00 2025-06-25T08:28:23Z Shutdown: done
Everything worked perfect after starting this journy with Start9 and my Bitaxe (lottery-miner), didn’t do anything.
What to do? thnx
I think 2 main issus here:
1)
and 2)
But maybe one causes the other ?? don’t know
I somebody could help I realy appriciate, thnx
Start9 and Knots are now working on Reindexing the blockchain. Hope this solves it
Re-indexing has completed this morning. Everything seems to work again.
Hope the re-indexings solves it. Why does this happen?
I’m still little bit confused…
It often happens when people lose power in the middle of writing a block. It’s not uncommon for some people to restart their server by just pulling the power, others will have a situation where there is power loss for some reason that goes unnoticed that does the same. It’s never a bad idea to have the server connected to a UPS. And if you worry the server lost power while you were out, asleep, on vacation etc, you can go to System → Monitor to see when the uptime is and if that looks off.
Was the fix here to reindex the blockchain? I’m running into the same issue
It would be the solution to a half dozen specific errors shown in the logs, and a good first step. If it doesn’t fix things, or things go bad again soon after, then there’s something deeper to look into.
Yes the fix here was re-index blockchain. It works fine again.
Had some issues with Electrs, but a new fresh restart solved that too;-)
HI,
I have the same issue as of about an 1hr ago…either Start9 lost power or my Internet connection went down.
When it says Please Rebuild index…does that mean System Rebuild from Start9 menu. I assume not?
All other service start and run but all are waiting on Knots wish is looping. I restarted the Start9 stopped all service from loading but still knots is looping. Should I just wait…and for how long?
How is that possible please. Un-install re-install Knots?
EDIT - answered my own question. Knots/Actions →
For anyone else reading… Bitcoin Core or Knots errors in logs may tell you to reindex, and that action is found under Bitcoin → Actions
Yes I did same: BTC Knots → Menu → Actions → Re-index Blockchain
Worded for me, now running for few weeks without issues;-)
