Knots not using port 8333
Hi. I have Knots running on StartOS v0.4 and I see it is using a non-standard port under Interfaces, Wired Connection 1, Local & Public. Is there a way to change the port to the standard 8333?
Are you looking at the Peer Interface?
Sorry, yes I missed that in my original post… Interfaces, Peer, Wired Connection 1, Local & Public
I’ve tried SSH’ing in and accessing the container with…
start-cli package attach bitcoind
… but I can’t find the bitcoin.conf file to add/edit the line “port=8333”.
you should not manually edit bitcoin.conf, especially not anything network related, this is all managed by StartOS.
It does not have to be 8333, the ports are automatically assigned by the bitcoin package and startos, you should not have to change it, just follow the instructions in the documentation and UI if you want to open/forward a port.
