Latest image doesn’t work on raspberry pi 5 8g
Hi,
I downloaded the latest img from StartOS and flashed it on a 64gig micro sd and put it on my raspberry pi 5 and doesn’t do a thing after turn it on.
Hi all developers!
I have good and bad news from my side.
The image that is downloadable on the GitHub page is not raspberry pi 5 bootable but after switching to the raspberry pi 4 4g it boots up!!
Now I have only a 64gig sd card I had to make it also as data folder. Can I change this when the pi head 2Tb nve arrives?
As I explained on the other thread, v0.3.5.1 does not work on the Pi 5.
While it will work on a Pi 4, it’s not a platform we’d recommend for intensive things like Bitcoin, but you can use it for other services.
No, other than doing it manually, there’s no way to move the data partition contents from one the microSD to a SSD. You’d need to start over.
