Ledger Nano X and Bitcoin Node
Is there some way I can use Bisq and/or my ledger Nano X linked to my Bitcoin Node on my start OS…
Mainly how do I use my StartOS bitcoin node with my ledger Nano?
You can install Bisq from the beta registry. Just change your marketplace registry to https://beta-registry.start9.com and You will be able to install it.
As for the Ledger, I use a Ledger Nano S Plus with Specter on the StartOS, this one is installable from the community registry. You can follow the following guide Start9 | Specter Service. Although it describes setting it up with a Trezor the steps are almost the same except when you select ledger and not a trezor.
I like Sparrow wallet for hardware signers
