Lightning channel loop out stalled
I have done numerous loop outs to balance liquidity and recharge btc balance to fund channel creation. I started one about 20 hrs ago and for some reason it stays on “Loop Out currently in progress” I don’t see why this happened but apparently it is possibel to see the block expiration height of all your payments with this command:
lncli listpayments --include_incomplete
I am on windows and use PuTTy app and this command doesn’t work. Any advise on how I might understand what’s happening with this loop out and what I can do about it would be much appreciated.
You can SSH into your server and check a few things:
Guide for setting up SSH
https://docs.start9.com/0.3.5.x/user-manual/ssh
To run lncli commands on StartOS:
  1. SSH into your StartOS device.
  2. Execute the desired lncli command within the LND container:
To list your payments issue command:
sudo podman exec -it lnd.embassy lncli --rpcserver=lnd.embassy:10009 listpayments --include_incomplete
To list your channels run
sudo podman exec -it lnd.embassy lncli --rpcserver=lnd.embassy:10009 listchannels
That worked, thank you.
Now just have to analyse the results.
I see the line “expiry”: 877408
Does it mean the process completes or fails at that block height?
The "expiry": 877408 means the Loop Out will fail if not completed by block height 877408. Until then, the process is still in progress.
I have copied ‘listchannels’ log and I would like to know how to figure out why the Loop out has failed so my next attempt might be successful.
I see a few “code”: “TEMPORARY_CHANNEL_FAILURE”,
and “attempt_id”: “31423”,
“status”: “FAILED”,
What do I look for to find the issue?
