When I restart LND, Zeus will no longer connect. My solution is: Every time I Restart LND (whether manually, after a backup or after a config change) Zeus can no longer reach the node through Lightning Terminal’s LN Connect. The solution is simple. I just have to remember to restart Lightning Terminal every time LND is restarted.
Perhaps this could be addressed at the OS level by auto restarting Lightning Terminal when LND is restarted? I’m assuming everyone would have the same issue if they use LN connect in this way. If not then my solution works every time… if I don’t forget to do it. lol
