LND errors HELP! - neutrino or / "Cert is not yet signed for current IP..."
Hi,
My LND is stuck in some loops. Currently it’s in this loop when I try to start it:
Cert is not yet signed for current IP…
and I can’t get out of it. I’ve tried AI and I found this: LND Error updating from 0.4.0 beta 9 to 0.4.0 stable and this LND stuck in "Cert is not yet signed for current IP" loop after recovery + IP change
This fix says “access the LND container” but I am stuck. Command line/terminal experience is null and SSH is not set up. My files are showing nothing. HELP! I have open lightning channels and don’t want them to close.
Sudo? LND container? Thanks for helping me… this is frustrating on top of a terrible week.
So, like the other post… had to use powershell, SSH and then let AI take over and fix… what ever was happening. Was a bit beyond my skills and understanding, but seems to have fixed it. If you are a user and get here… go to the links above, paste them in an AI and tell it to walk you though the fix step by step. Powershell, SSH connection, then let it write the code copy/paste.
