I’ve looked around the forum here and found the post below but I don’t know where to begin with this Chantools fix… I’m not a coder but can follow clear instructions
It’s been spinning for days… I’ve rebooted, stopped and started… did a reset… what do I do from here… I can send logs to Start9 support
Really appreciate any help
p.s. it’d be amazing if you could code in zaps on this forum? Happy to tip great advice
It stopped ages ago and I rebooted it and that seemed to work… then again a few weeks ago I think, and again I rebooted and it seemed to work… but this time has been since last week
I’ve had this node a looooong time… this isn’t a new install of LND, unless you’re counting the reset…
It’s only using 40% of the disk space
“you have no bootstrapped peers” - is this channels I’ve opened with other nodes? I have at least 6… it was twice that a year or so ago but some have dropped off
I’ve just hit Restart again for the sake of it and it’s back to “Syncing to graph and chain”… been like that for 15 minutes now
I’ve got the logs open but honeslty can’t really see anything glowing in red and nothing obviously screams “Error”
The issue is LND kept restarting because it couldn’t communicate with the system dns server to resolve bitcoind.ebmassy:
unable to determine if wallet is synced: failed to parse address lookup bitcoind.embassy on 172.18.0.1:53: read udp 172.18.0.149:56271->172.18.0.1:53: read: connection refused
It’s not that the DNS resolver couldn’t resolve it, but the connection to the DNS server to even ask was refused.
Developer comments: Something malfunctioning with the systemd dns resolver, possibly binary corruption. Reflash as suggested solution. So I instructed @Chiefmonkey to reflash the OS:
Follow the flashing guide to burn the latest StartOS iso to a usb thumb drive
boot the thumb drive in the server. It should boot to the StartOS live installer
You can either plug in a monitor, keyboard & mouse to use “Kiosk mode” to reinstall it, or you can visit http://start.local in a webbrowser from another computer on the lan to see the installer web-UI
Choose Re-Install StartOS
It will instruct you to remove the USB thumb drive and reboot
When you reboot, re-visit http://start.local (or you’ll see the setup UI now in Kiosk mode)
At that setup screen, choose Recover > Use Existing Drive
Select the disk and set your password
Then he’ll be back in action (in theory). Now we await Chiefmonkey’s feedback!
Your Mac not recognizing the drive after it’s been flashed in normal, yes.
With the booting of the USB… can you remind me what hardware this is? One of the challenges with posting for help in multiple locations is that it’s hard to keep track of everything when it’s spread all over.
I could have sworn you’ve previous showed me a Raspberry Pi. If so, while George’s steps above would be correct for most people, you’d need to do something slightly different… Flashing a microSD card.
Apologies… I’ve committed the cardinal sin of posting in multiple places… really don’t want to be a pain… just want to get this fixed and get on
Is it a Raspberry Pi… I honestly couldn’t say… possibly… I got a pretty early one… one of the first to get a metal case after you stopped selling the transparent plastic housing because they kept melting
But then later had to transfer the guts to another new metal case in order to house the additional hardrive
I’ve flashed 2 usb’s not a microSD… and the Start9 just boots up as usual… I’ve tried both in blue and black slots… Start9 doesn’t seem to recognise them
They are definitely flashed correctly though… as previously mentioned, the mac doesn’t even see them after flashing with the startos-0.3.5.1-39de098_x86_64-nonfree.iso
So I think everything is OK so far
Just need the device to boot off one of the usb’s now
Got it. The confusion was down to the fact that we now assume people aren’t running these older RPis for Bitcoin… we very strongly recommend against it since they haven’t really be able to run Bitcoin adequately for over a year now. I haven’t seen the logs, but this could well be a factor in what has happened to your LND.
I flashed the MicroUSB… the one you guys issued years ago… stucj it in the Blue slot and yeah It’s recognised it and booted … I did a ReBuild and it bleeped differently than usual
So it’s finished that and I’m now back to this screen
I guess I need to wait another 24 hours to let the LND catch up right?
On a seperate note
If this machine is now dead/dying… always going to fall over like Biden… do I need to buy the latest and greatest?
MEGA
Make Embassy Great Again
Seriously… do you recommend I buy the Server Pure OR should I wait for the full Router to come out and how easy is it to upgrade from the old rattler to the new shiny thing?
We’re going to be building the new Plebeian app for Start9 soon so going to be testing it
Re: LND… I’m not sure. If it’s working not and progressing, and if it’s finished by now, then we’re good. If not, it’s time for round 2.
Re: New machine… Either the One or the Pure are fine for a predominantly or only Bitcoin us. Wouldn’t matter too much which you get. I’d be willing to bet a small amount of money that your RPi will be dead before the router is born… but the two are unrelated otherwise. Migration is simple between the two, there are guides, but with a powerful machine it can be fun to start over and watch in sync in a day.
