Lost charging cord for Sever Pure
How embarrassing. Long story but I misplaced the charging cord for my Server Pure. Found one that fits but don’t know if it’s correct. Would someone take a pic of theirs, and/or tell me the specs of the AC plug.
Thank you
SJW
Hey SJW,
No worries, these things happen! The important part of the power supply for Server Pure is that it provides 19V output. You also need to make sure the connector size is 5.5mm (outer) x 2.5mm (inner) to fit properly.
If the charger you found matches these specs, it should work fine. If you’re unsure, you might want to double-check before plugging it in to avoid any issues. Let me know if you need more details!
Hi H0mer. You’ve helped me before. Thanks for the prompt response. You saved me from an error. Rearranged the office and somehow the cord disappeared. This will help me recognize the right one. Or else I’ll be buying a replacement…
SJW
Found it! Thanks again for your help.
