Market place not loading
Had a successful 0.3.3 install on Lenovo t550, but not able to reach the market place and registry update failed to update, hoping someone can help, I’m somewhat of a newbie here, I do have a umbrel node running on a pi. Embassy seem to be somewhat different
Need some more info please, what errors are you getting? Are you using ethernet?
The error is Registry request failed, I am connected by Ethernet to embassy os computer and also use another computer via local network over Wifi. Have been able to get registry a couple of times but not consistently
What kind of connection is it? What hardware is being used in the network? Are you using a VPN or firewall? If you can reach it sometimes and not others, it is almost certainly a problem with your network
