I can’t get memoool to launch post 3.0.1 update.
Looks like the install finished but no luck on the health checks. Any ideas? Tried uninstalling and reinstalling but no luck.
This is the container getting into bad state. Uninstalling and reinstalling should have fixed it, but it look like it went right back into a bad state!
The fix:
System → System Rebuild
Like your reinstall approach, but a bit better, it’ll rebuild the containers from scratch (while preserving the data) and get it back into working order.
