After successfully installing the Mempool and Jam app… Clicking on the Launch UI button takes me to a new web browser tab that states ’ This site can’t be reached? BTW my .local name for Start9 Home works ‘Market Place’, ‘System’, “Connected” green check at bottom etc… Also the Tor addresses for Mempool and Jam work fine. Is this a DNS issue?
I have uninstalled and reinstalled Bonjour multiple times using the guide… via System Settings > Remove Programs.
The steps you already took to connect via Tor and un/reinstall Bonjour were the right ones from a troubleshooting perspective. This could be an MDNS issue on your client device – It is very common with Windows machines. Service .locals are MDNS “aliases”, whereas the main UI is an MDNS primary. For some reason, Windows and sometimes other devices just hate aliases. This is something that the team is working on obsoleting in upcoming releases of StartOS.
Have you tried accessing your Mempool and Jam .locals from another device (e.g., phone/laptop)? That could be a helpful next step to better isolate the issue to the original client device. Let us know.
Thanks for the reply I will try another device that was next on my list. I can ping and nslookup the adjective-noun.local domain no issues. It’s just the Jam and Mempool .locals so I believe you are correct. Also no issues with other .local domain I have setup.
Ok I installed the cert on my iPhone 15 iOS 17.4 and same issue? Start 9 main works fine so does services page, etc as seen in screen shot (removed the adjective-noun from screenshot) . So I figured maybe Mempool had an error installing did an uninstall/reinstall same issue?
I also run MyNode in https and Mempool works fine using the alias although they use a simple URL with just the port number. Also running mutiple Synolgy NAS’s on the network using aliases never have an issue reaching them.
OS logs are just full of:
2024-02-07T15:20:01-05:00 2024-02-07T20:20:01.641868Z DEBUG run_main:check: startos::manager::health: Checking health of bitcoind
2024-02-07T15:20:11-05:00 2024-02-07T20:20:11.659132Z DEBUG run_main:check: startos::manager::health: Checking health of mempool
2024-02-07T15:20:13-05:00 2024-02-07T20:20:13.916584Z DEBUG run_main:check: startos::manager::health: Checking health of electrs
2024-02-07T15:20:17-05:00 2024-02-07T20:20:17.454027Z DEBUG run_main:check: startos::manager::health: Checking health of bitcoind
I finally got this working so I thought I would report back so it helpfully helps someone else. I use a Ubiquiti UDM-SE for my home network. My node is running in a separate VLAN from my PC. You also must obviously create some firewall rules but that was not the issue. The issue was I had to enable Multicast DNS in both VLANS for it to work.
Hello. I am having the same issue you had. I’m unable to enable the Multicast DNS in both VLANS. My eero router has very limited configuration capabilities. Which router do you have? Any input is much appreciated.
EZ Fix For Me - Make sure Bonjour64 is installed …
For anyone on Windows specifically, if you still can’t get the .local to work after enabling mDNS, make sure you have Bonjour64 installed and the service running. I went through so many hours of networking hassle and found out it was just the service that wasn’t installed and or enabled because of windows. You can easily do a google search and find the download in the Start9 Guides web page. Good luck!
