Mempool service not starting on 0.4.0
Hi,
I just upgraded from 0.3.5. to 0.4.0 Beta 1 and then beta 2. Process was quite smooth and after every services was upgraded it works flawless. Im on a DIY-VM on Proxmox.
However Mempool does not start. I use electrs and I get the following log lines:
2026-04-05T09:54:20+02:00  Apr 5 07:54:20 [123] NOTICE: Starting Mempool Server... (32fadb4)
2026-04-05T09:54:20+02:00  2026-04-05 7:54:20 20 [Warning] Access denied for user 'mempool'@'127.0.0.1' (using password: YES)
2026-04-05T09:54:20+02:00  Apr 5 07:54:20 [123] ERR: Could not connect to database: Access denied for user 'mempool'@'127.0.0.1' (using password: YES)
Those are repeating.
I tried already to ā€œrebuildā€ the Mempool service, and completely uninstalling and reinstall it, that does not change the result.
Any ideas where else to look?
Thanks, we’ll look into it.
Wait, you said you completely uninstalled Mempool, then installed it completely fresh, and got this error again?
yes. completely removed Mempool app via uninstall button, then installed again.
Can you confirm the exact version of StartOS and the exact version of Mempool?
Mempool version 3.2.1:9
StartOS is 0.4.0-beta.2
electrs is 0.11.1:1
After checking electrs logs i can see a matching pattern which is also repeating over and over:
2026-04-05T16:45:54+02:00  [2026-04-05T14:45:54.908Z
 WARN  electrs::server] 615: failed to shutdown TCP receiving Transport
endpoint is not connected (os error 107)
2026-04-05T16:45:54+02:00  [2026-04-05T14:45:54.908Z WARN  electrs::thread] recv_loop thread failed: 615: recv failed
2026-04-05T16:45:54+02:00  [2026-04-05T14:45:54.908Z WARN  electrs::thread] because: Connection reset by peer (os error 104)
Electrs is working with my Specter wallet.
Could you please download the full Mempool logs (it outputs a html file) and email that to me at stu@start9.com ? Thank you.
I have a similar error with a fresh install of StartOS (not a migration from 3.5.1).
-StartOS is 0.4.0-beta.5
  • Fulcrum is 2.1.0:7
  • Mempool 3.2.1:9. I have uninstalled and reinstalled multiple times now, am downgrading to 3.2.1:8 to see if that works.
The below repeats over and over in the mempool logs. I can ssh into the server & can download via CURL the ā€œpools-v2.jsonā€ file no problem, so it doesnt appear to be networking issue.
2026-04-17T10:22:02+10:00 Version: ā€˜10.4.32-MariaDB-1:10.4.32+maria~ubu2004’ socket: ā€˜/var/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
2026-04-17T10:22:03+10:00 daemon sync waiting on api
2026-04-17T10:22:03+10:00 Launching api…
2026-04-17T10:22:04+10:00 daemon sync waiting on api
2026-04-17T10:22:06+10:00 Apr 17 00:22:06 [2] NOTICE: Starting Mempool Server… (32fadb4)
2026-04-17T10:22:06+10:00 Apr 17 00:22:06 [2] INFO: Database connection established.
2026-04-17T10:22:06+10:00 Apr 17 00:22:06 [2] INFO: Connected to Electrum Server at fulcrum.startos:50001 ([ā€œFulcrum 2.1.0ā€,ā€œ1.4ā€])
2026-04-17T10:22:07+10:00 Apr 17 00:22:07 [2] INFO: [PoolsUpdater] Downloading pools-v2.json for the first time from https://raw.githubusercontent.com/mempool/mining-pools/master/pools-v2.json over clearnet
2026-04-17T10:22:10+10:00 Apr 17 00:22:10 [2] ERR: [PoolsUpdater] Could not connect to Github. Reason:
2026-04-17T10:22:10+10:00 Apr 17 00:22:10 [2] ERR: Failed to retreive pools-v2.json sha, cannot run block indexing. Please make sure you’ve set valid urls in your mempool-config.json::MEMPOOL::POOLS_JSON_URL and mempool-config.json::MEMPOOL::POOLS_JSON_TREE_UR, aborting now
Thats not a similar error, your instance can connect to MariaDB.
Instead it looks like it cannot connect to https://raw.githubusercontent.com/mempool/mining-pools/master/pools-v2.json
Make sure that this is not blocked by pihole etc. and your DNS resolving is working properly
