Migrating to Ubunutu VM inside proxmox
After much research I’ve decided my needs don’t fit within the start9 ecosystem any longer. I’m wondering if there is an easy and known way to transfer the blockchain to another drive inside my ubuntu VM where I’ll be spinning up a node. I can redownload but I’d like to hold it on my HDD to save SSD space and downloading onto the HDD will be a long process.
I’m sure there is a way I just don’t see it well documented or I didn’t do research well enough to find it. Any help would be appreciated. My guess is accessing the currently running server from ssh inside ubuntu vm and running a copy.
SSH into your server, cd into the bitcoin volume and copy over the block data. Both StartOS and Ubuntu are plain old Debian Linux underneath… if you’re comfortable with running Ubuntu and installing Bitcoin, you shouldn’t run into any issues.
