My ServerOne runs fine. However, I can’t connect to it across my lan without running the installation repair for Bonjour. Once I run the repair my connection is robust until the next reboot of my Windows PC. After a reboot, I can’t connect unless I run the Bonjour repair function. This isn’t a showstopper for me, but I wonder if anybody else sees this?
You might want to switch up the steps you’re taking to try to make this infuriating software stick.
Next time, uninstall Bonjour completely, install the version we list here: Start9 | Connecting Locally
then seen what happens.
