Upgraded to 0.4.0 on Server Pure without issue. Was running Nextcloud (legacy) on prior install, have a backup. Upgraded to Start9 registry version of Nextcloud 33 - able to log in but database not populated with files from prior version. Is there any way to use the pre 0.4.0 Start9 backup of Nextcloud to populate the current Nextcloud version?
If you carefully follow the instructions for updating to 040, all the files in your Nextcloud should have been migrated without any problem.
https://docs.start9.com/start-os/0.4.0.x/update-040.html
Since you have a Start9 Server Pure, you have access to our private support server where we can go step by step with you and get you back up and running.
When you purchased your server, you were provided a unique code that can be used to log into the support server here: http://start9.me/
