Nextcloud not working
Hi everyone,
I’m having some issues setting up Nextcloud. I’m connected via Wi-Fi on a local network, and I can see the server using the .local address — everything appears to be working fine. The Nextcloud service is running, health checks are all OK.
However, when I click “Launch UI”, the web interface doesn’t load, and I’m unable to connect. The same thing happens when I try to set it up on Windows using the Nextcloud Desktop Client — I enter the local network address, but it can’t find the server.
What could be causing this issue?
If you need my logs i will share with you!
Thanks in advance!
On Windows, it’s very important to go through the entirety of the guide, in particular this part:
https://docs.start9.com/0.3.5.x/user-manual/connecting-lan#connecting-lan-windows
