Nextcloud on IOS not logging in with .local address
Nextcloud on IOS not logging in with .local address.
Error message: "Connection error. The internet connection appears to be offline.
Using iphone XR.
StartOS DIY node connected to Windows machine.
I’ve trusted root CA on phone.
Running Bitwarden from phone no problem.
All services running green on server.
Please make sure you are connected to the same network as your server, also it is a good idea to attempt the .local connection with any VPN you might have turned off.
Here is our guide for setting up Nextcloud on iOS. If you haven’t already, go ahead and follow it carefully step by step.
If it is still giving you trouble let us know.
