My node is fully synced but is not showing up on bitnodes.io
I tried the onion address without the http:// still nothing… Is that the address that I should be using to see it on bitnodes.io?
I’m pretty sure it is because it is a Tor node, not a clearnet node. If you click on Properties tab, you’ll see your nodes connections. If it’s working, you’ll see inbound and outbound. Sometimes it can take a while of to get inbounds though.
Correct, bitnodes.io would need to support private tor nodes.
https://bitnodes.io/nodes/*********.onion-8333/
enter your peer interface
