Nostr NIP-05 Verification using Start9 Server
Hello,
I was wondering if it is possible to use your Start9 server to NIP-05 verify a Nostr account. An AI has given me the SSH code in order to do this but I thought I would ask here if this is a good idea. Is the AI even right in telling me this is possible? I’ve posted the instructions the AI gave me below, does it look right?
Thanks guys
Technically yes, practically no, kind of. Firstly, anything AI tells you to randomly type into a terminal window is probably not a good idea.
Next, Services on StartOS are what actually do things, and you’d need a service that has this feature. LNbits is one, via a plugin.
That said, until you’re updated to StartOS v040, you’re not going to have a server running with clearnet features that can easily be reachable over clearnet with the DNS system, making this impractical. When running StartOS v040, the answer will be yes.
