hey!
just wondering about using the tor nostr relay
I’ve tor running on my device, but I can’t add the tor relay to the primal app
it asks for a wss and not ws
basically how to I use my nostr tor relay with nostr clients!
cheers!
hey!
cheers!
Not all Nostr clients accept the use of a .onion address for relays, yet.
You could use the Nostrudel service provided on StartOS or any other mobile client such as Amethyst which does allow the use of .onion relays.
Thanks!
I don’t have Tor installed system wide on my machine, so I think Nostrudel is out of the question right?
Do you know of an ios nostr app that allows tor relays?
Is running your nostr relay necessary for remembering/linking your notes followers etc over time, and across platforms, or is that something that the free relays will provide?
very green nostr here - thanks!
Having Tor run in the background of iOS or any other OS is not a big deal. Takes just a few minutes to follow each guide.
For Primal, if you have it add to Orbot, forcing the full relay address to have the prefix ws:// should work… it used to, at least.
hi stu
as mentioned in my other thread - I’ve gotten nostrudle working via the .onion url, with background os tor - I’ve added my Nostr RS Relay and whitelisted my hex’d nsec - however in Nostrudel it’s timing out, and constantly has a red circle surrounding it signifying it’s not connecting.
I SHH’d into my server with
sudo podman exec nostr.embassy sqlite3 /data/nostr.db “SELECT content FROM event;” | grep -o ‘content":“[^”]*’ | awk -F: ‘{print $1":"$2}’
And got no content back.
Can’t figure what I’m doing wrong – many thanks
about:config and set network.websocket.allowInsecureFromHTTPS to true. This is necessary to access you ws:// URL, since Tor does not use wss://thanks - those are now set, but ‘relay connection timed out’ is still occurring, and nothing coming back from DB query
thanks!
Hi @therealway
Were you able to connect your Nostr Relay ?
It was really easy for me to set up my Nostr relay. The only trick is to get your npub in hex format. I also found that Nostrudel is much stable than other clients for Mac users.
Hey (again)
@Ethan369 - I must check again, good to hear it’s working. Yea I hex’d and SSH to check if something was written to the DB. Did you confirm you got it working by checking the DB (did you see notes written to it?)
Did you use ws:// ?
Thanks!
I use ws:// and it WAS working for some time. What I did was to add it to my NIP-05 Relays, so now I can check without SSH if it is storing stuff from NoStrudel. Sadly it stop working last week and since there I get a “Relay connection timed out” notice =(
I was thinking in switch it to a public relay as an experiment only to see if it works.
