I love being active in using “noStrudel.” However, today is the second day that an error saying “Something went wrong Missing Kind” is showing up.
I have stopped and restarted the service. After the same error persisted, I deleted it from the interface and reinstalled it, ›to get a new link‹ (http/https : dfhlsdkjh……onion/local). It worked at first, but after moving to other tabs, the error still started to appear.
Reloading with “Shift+Command+R” shortcut helps a little, however, the problem reappears and I know that it is not the proper representation and use of the service.
Have you tried looking into your noStrudel logs to see if there is any furhter indication around the error in there?
Might be helpful to see what, if anything, it says in there around the times of the error showing up.
I have not seen any mention of this happening with other users just yet so your logs might be the best place to start since you have already done the 1st step of doing a Hard Refresh of your browser & have restarted the service already.
I checked the long list of “Service Logs” and to move forward, hoping that another maneuver could get the service working as it was three days ago, I performed a complete disconnection of all the machines and even turned them off. When I restarted, the same error continued to appear. Only this time it is not so persistent, that is, with a single reload of the browser (Command+R), the messages are displayed correctly.
Here is the “Service Logs” screenshot I took shortly after having restarted “Internet-Modem/SO/Services/noStrudel.”
