I flashed the latest Start OS ARM version onto a Micro SD as instructed in Odroid M2 installation documentation. Power it on and nothing shows
Tried it with the switch on Micro SD and on eMMC mode.
When I remove it, it starts to book the onboard images of Ubuntu (proof the device is working correctly)
I was following Claude’s instruction to try boot it from within Ubuntu, and told it:
‘ls /dev/mmcblk1*’ just returns /dev/mmcblk1
It replied:
"That’s the problem! A properly flashed StartOS image should have multiple partitions like:/dev/mmcblk1p1 (boot partition)/dev/mmcblk1p2 (root partition)etc.
Since you only see /dev/mmcblk1 with no partition numbers, the StartOS image wasn’t written properly to the SD card.You need to re-flash the StartOS image. Here’s how:
First, unmount anything that might be mounted:sudo umount /mnt/startos-boot 2>/dev/null
Download the correct StartOS image for Odroid M2 from the official StartOS website"
Has anyone else done this? What image do I use?
