Ollama | FREEGPT-2
Doesn’t matter what model I run or whether I uninstall and reinstall FREEGPT-2. No matter that prompt I give to any model it results in
500: Ollama: 500, message=‘Internal Server Error’, url=‘http://localhost:11434/api/chat
Is it possible that you did not install the model you are trying to run? FreeGPT’s instructions (Steps 3/4) explain how to install models.
You should also look at the logs for FreeGPT2 - that may give you more information as well.
The same error happens with Arena model the pre-installed one and its a fresh FREEGPT-2 install.
The model I installed verified rhe SHA and was successful. Been happening for a couple months. Just started out of the blue. Doesn’t matter what model.
I’ll check out the logs and see what I can spot.
Any internal server error should make it onto the logs.
