So I started the node.
Transfered 3 million sats onchain.
Open an channel (3 million) with start9 node.
Channel created successfully.
But Onchain is now still showing that i have 3 million available.
Is this a bug? My Umbrel with the same workflow shows 0 sats as onchain.
If you moved the sats from onchain into a channel, the sats should be removed from the onchain balance. Not sure what’s going on here. Give it a little time. Double check the amount of sats you delegated when opening the channel
Similar issue. I’ve opened two channels. Node shows online at Amboss, Thunderhub, Lightning Terminal and RTL. On chain balance is wrong. I couldn’t open channels. I think the balance issue is why.
The last major change I made was setting up a Watchtower with LightningNetwork Plus. I shut that down and restarted LND. It’s took longer than usual to sync to graph. The Log said it was rescanning addresses starting back at block 791211. Hope this finds the TX.
Oh, I forgot. I think, turning of the Watchtower did nothing for me. My next step was: Goto ‘Actions’ in the LND service and “Restart Wallet Transactions”. That’s why it’s resyncing to graph. I’ll let you know just the same.
Sounds like you might be approaching a resolution with this. Please keep us posted for the visibility of others facing the same issue. I will just add since you made a reference to restoring Lightning from backup, that in general this should be avoided and only used as an emergency/last resort option. Doing so would force close all channels, which could take multiple days.
My next problem. Tried to open new channels. They failed because of minimum channel size. My balance is off again by the amount attempted. Will start a new thread for that.
