Orange Flashing Light
Hello!
We just set up our server and noticed an orange flashing light on the left side of the ethernet cable and a constant green light on the right side.
Is this ok or did we setup incorrectly. Apologies in advance, we are not so tech savvy : /
Thank you for your time and help!
Hi there.
What Server did you get?
From what you are describing about the ethernet cable, that sounds normal. Have you run through the Initial Setup guide yet? If not, here is a link to that for you → Start Fresh
Hi, thank you for your reply!
Yes, we ran through the setup guide and have synced Core and Electr. Happy to hear that the orange light is normal!
