Pem encoded key
Hi, now there’s another issue with the PEM-encoded key. When I try to link server start9 to the VPS and stack here, it says an SSL certificate is required. You can have StartTunnel generate a certificate signed by its own Root CA, or provide your own certificate (and key).
SSL Certificate: Provide
Please paste in your PEM encoded private key: I am totaly new to all this and I want to learning.Thanks.
Make sure to follow the instruction in our documentation here:
https://docs.start9.com/start-tunnel/1.0.x/
They should guide you step by step on setting everything up.
Hi, thanks for the reply. I followed all the steps, and indeed all sort it from satashi youtube channel.
Thanks, Alvaro. All done and working fine. Many thanks.
