Permanently set MTU on StartTunnel for Tor to connect
Tor on 0.4.x won’t connect to my StartTunnel VPS (T-Mobile internet provider) unless I run
sudo ip link set wg0 mtu 1280
The problem is when I reboot the server, the MTU goes back to 1420. Some of the things I have tried to make the change permanent:
  1. sudo systemctl edit wg-quick@wg0
  2. setting MTUBytes via /etc/systemd/network/10-wg0.link
  3. setting mtu via /etc/udev/rules.d/10-mtu.rules
Any ideas appreciated.
you could install this toolset and setup a crown job every hour then to reset or even check MTU, problem is you need to re install it after an update but not every reboot. I am using this for automated backups. Below are the intrusctions for entering persistent mode if you dont want to use the tool itself
Are you running the latest versions of StartOS 0.4.1.1, Tor (Service) 0.4.9.15:0 and StartTunnel 1.5.0?
I was on StartTunnel 1.3.1, but after upgrading to 1.5.0, same issue. Got latest on Tor and StartOS
Thanks Jesse, I will look into this.
