My new install of core lightning is giving the following repeating error:
Starting Wait for Bitcoin Start
2025-03-04T13:57:42+00:00 Cleaning old lightning rpc
2025-03-04T13:57:42+00:00 Fetching system cert for REST interface
2025-03-04T13:57:42+00:00 Waiting for system cert key file...
2025-03-04T13:57:43+00:00 Waiting for system cert key file...
2025-03-04T13:57:44+00:00 Waiting for system cert key file...
2025-03-04T13:57:45+00:00 Waiting for system cert key file...
2025-03-04T13:57:46+00:00 Waiting for system cert key file...
One then has to uninstall as stopping the service doesn’t work.
I am using Bitcoin Knots as I want to use Datum gateway if that makes a difference.
I have a instances of LND and Alby hub which is running fine.
I’ve had a good search but to no avail. Any help is appreciated.
In that case, rather than providing you with information that shouldn’t really form part of StartOS support for you to perform actions that you shouldn’t need to do at all… we’d instead need to work on addressing the actual problem.
Out of every user of StartOS that has installed CLN fresh without a problem, what makes your situation different? Hopefully it should be something obvious that you can declare right away. If we can identify something, then we have something to work on.
Unfortunately the keys and directory below have not yet been created. When I get some time I might rebuild the system, installing core lightning first but I’ll need to get some time to do this.
I was looking how to manually create the keys from the blockstream instructions. I’ll have to invesigate this further.
