GM
Has anyone updated Proxmox 8 to 9 and run on this machine Start9 in a VM?
My question is, is it safe to update or should I waitđ
StartOS itself wonât care about the underlying virtualized hardware if that hardware is kept the same. So I guess the question is⌠is Proxmox 9 full of bugs? That I donât know.
Thats clear for me but it would be nice if somebody had tested this configuration and can tell if there are any problems.
Maybe @OKIN has, or will be soon.
Hi Sirius,
Iâm running StartOS 0.4.0 alpha as a VM on Proxmox 9.0.3, and everything looks stable and running smoothly. One feature I particularly like is the snapshot functionalityâitâs going to be very handy whenever I start experimenting and âbreakingâ things.
Thanks, thats good to know that its runnig smoothđ
You mean the normal Snapshots from Proxmox? These are great but it took a while for 2TBđ Anyway I will use them before I upgrade my system and will see.
I unfortunately had to nuke my Proxmox setup because of my own user mistakes so havenât had the chance to do the upgrade, but I donât see why the upgrade would be a problem as it never has been before.
I upgraded my Proxmox 8 instance to 9 this morning. I followed the upgrade guide, and it went smoothly. Was back online in under 20 minutes.
