I plan on getting a knots node running using a Nuc 14 essential barebones mini pc. I have seen tutorials with people flashing StartOS on windows 11 but not with barebones pc.
Does start9 OS install directly onto a barebones mini pc without any pre installed OS?
How does this work if there are no ethernet drivers?
What i mean is, a barebones pc has no ethernet drivers so i assumed StartOS wont connect to the internet. Was thinking i needed another OS to get the drivers and have both OS, my bad still new to this just had a relative advise on mini pc and parts list.
So a better question, if i have StartOS flashed via usb to my mini pc then it should already contain ethernet drivers on start OS to connect through ethernet?
Often a barebone PC has no RAM, or storage drive. So the PC may not function at all, until you add these components. I’d recommend at least 16GB or RAM, and a 2TD or 4TB SSD. You will need another computer handy, and a USB drive, to download and flash the StartOS ISO to, which you will used to boot and install on the Nuc.
