Remote access how to / connectivity monitor
Hi all, any step by step instructions on how to setup remote access to my Start 9 OS ?
I have an iphone and wanting to remotely check if my node is running from time to time.
Also - any creative ways others ensure their node is actually running without having to remotely connect to it ?
HI, what version of StartOS are you on? Running version 040 makes this trivial by using StartTunnel and then just opening up individual services via clearnet, but if you are on version 0351 still then this guide should get you sorted - Start9 | Running Tor on iOS
Please note that iOS and Orbot don’t always play well together
I am running on Version 0.4.0-beta.9
Then have a read through our Remote - StartOS docs for 040 to see which option you’d like to follow.
Thank you !
Question - I want to expose main server dashboard screen that I use when local however via Ios.
Instructions say “Navigate to the service you want to expose over Tor.” What service is the dashboard so I can add .onion to ?
