hie everyone,
is there another way to Remote access StartOS than the Tor Adress ? I had no success so far with Tor.
Any advices ?
Thx in avaqnce,
hie everyone,
Any advices ?
Thx in avaqnce,
I will be with the next version of StartOS (v0.4.0). This version (v0.3.5.1) is accessible via Tor.
Hopefully Tailscale will be available with the new release.
thx … is there a release date ? it is just not very functional with TOR if you go somewhere and need to access your startOS
I had issues with TOR as well. Once I setup Tailscale everything worked really well. For that reason I will stay with Umbrel. My preference though it Start OS.
All sorts of options, some probably better than trusted third parties.
My Bitaxe and Avalon Q are at my workplace and connected to my workplace wifi but since my workplace has a firewall preventing access to any pool mining websites, thus I can’t pool mine. I do have access to public pool and have been solo mining so far. How can I point my miners using workplace wifi to my start9 server at home where I have Datum gateway?
Can I SSH into start9 and install Tailscale? Is this safe or will it brick the start9 server?
