Thank you for your help. How does a person remove (or unmount) a USB drive from a Start9 that is running?
You can just remove it from the USB port.
There is no unmount button for these as there is with a laptop/desktop.
Also worth asking what you mean by ārunningā. That it is plugged in? Or that is it writing?
Is this a backup drive?
In between backups, drives are unmounted, as Okin explains. Mid backup, or if your drive is an actual data drive⦠obviously donāt unplug it ever.
By ārunningā, I just mean the Start9 system is on. These are backup drives, yes. I wait for the backups to complete.
OK great, yes, when thereās no backup running the drives are not mounted.
