I am having a problem getting RTL to see my LND node. LND is running and it says it is synced. Thank you for your help.
Hi.
Just a few questions so we can get some clarity on what might be happening:
- Are your
Health Checksfor RTL Green? - Are there any errors that you are seeing in the logs of either LND or RTL that indicate a problem?
Thank you for your help. A little background, it seemed to be working until I changed the node alias. That is when I started getting the error. I uninstalled both LND and RTL and then reinstalled them. That did not help.
LND has a green check and says: āSuccess : Synced to chain and graphā.
RTS also shows a green check and says: 'Success : RTL is ready to visit in a web browser '.
At the top of the dashboard, it says āError! Please check the server connection.ā
The last log entry is: ā[5/20/2024, 12:24:54 AM] ERROR: Wallet => List UTXOs Error: {ānameā:āRequestErrorā,āmessageā:āError: connect ECONNREFUSED 172.18.0.41:8080ā,ācauseā:{āerrnoā:-111,ācodeā:āECONNREFUSEDā,āsyscallā:āconnectā,āaddressā:ā172.18.0.41ā,āportā:8080},āerrorā:āError: connect ECONNREFUSED 172.18.0.41:8080ā,āoptionsā:{āurlā:āhttps://lnd.embassy:8080/v2/wallet/utxos?max_confs=1000000000",ārejectUnauthorizedā:false,ājsonā:true,āheadersā:{},āmethodā:āPOSTā,āqsā:{},āsimpleā:true,āresolveWithFullResponseā:false,"transform2xxOnlyā:false}}ā
Changing a node alias does not break LND or RTL. You have some other error that is behind this that uninstalling and reinstalling these two services is not going to fix.
Iād suggest first restarting your server, then checking whether you have the basics of RTL configured right, then clicking Save.
Thank you. I restarted. Then LND would not synch while RTL was trying to start. I reinstalled RTL and now it works. Iām not sure what the problem was.
I appreciate your help.
