Hi - Any ideas on when Robosats service will get upgraded?
I don’t have the skills to “update the Docker image yourself”!
It’s being worked on already, a few kinks to iron out, but no firm date on when it’ll be done. v0.5.3 still works, I’ve used it myself this week, you just won’t be able to use the other coordinators on your self-hosted instance.
v0.6.0 is in Alpha testing. Working with the upstream devs on a bug at the moment. No ETA right now.
Hi, is the upgrade to 0.70 alpha coming? I am getting errors with 0.60 now.
Thanks.
It is currently still working with the 0.60 version despite the error warnings. No Official ETA but the upgrade is being worked on
Thank you for your reply and assistance.
Yes it’s in alpha testing now.
Is robosat up to date? It throws some conflict
I checked under https://beta-registry.start9.com/
I see version 0.7.1 there but everywhere else is 0.6.0
Is it safe to upgrade to 0.7.1
If you have any real money at stake, you probably should wait until beta testing is completed. If you are able / willing to beta test, that would be helpful…
Following on from what Jesse has said, where generally you shouldn’t go about installing Beta software unless you’re sure of what you’re doing…
In this specific situation…
At the time of writing, this specific warning (there is no “conflict”) when you open RoboSats is fine to ignore.
RoboSats is slightly out of date because we spent quite a lot of time trying to make it work over the LAN interface but ran into issues with third party dependencies.
The v0.7.1 version I believe is the one with the code we’re stripping out. I’m running v0.7.2. alpha, which works fine. This is also a little behind schedule since we’ve been super busy over the holidays.
v0.7.3 was released by the upstream devs, meaning we now have to work on that, adding another small delay.
I’d stick to 0.6.0 a little while longer, and I’ll check on 0.7.3 progress,
RoboSats 0.7.4 was Released: Mar 3, 2025, 5:04:37 PM on the Beta Registry. I just asked on the matrix channel for RoboSats devs if there is an ETA for when it will finish beta testing…
I’m not as involved as you are but what you shared does that mean Robosats has the update but Start9 doesn’t?
It means you can update from the Beta registry if you add it as a source for the marketplace OR you can wait a few more days (let me see about getting it published now, actually).
If you can’t wait, the beta registry is at: https://beta-registry.start9.com/
Go to Marketplace and click on “change” It will be directly under Start9 Registry.
When prompted, click Add custom registry, then enter the beta registry address from above in the URL field. then click save and connect.
No need to wait any longer. Robosats 0.7.4 is past beta and is now available in the main marketplace.
Yes, I upgraded and use it thanks…BUT --------> Need more apps in marketplace I ask myself is the Start9 team still going?
We don’t develop any of these services in the marketplace. Just list the one’s developers create and package. The Start9 team works on StartOS.
What would you like to see? And is the developer contactable?
