I installed Robosats on my Start9. When I go to launch UI I get a Server Not Found error. There’s not much to the configuration of Robosats. I did notice that the LAN address is N/A in Interfaces. I’m running Knots instead of Bitcoin Core. That shouldn’t matter though. Has anyone run into this? The .onion address it’s trying to connect to is the correct address. Cheers.
You clearly don’t have TOR set up in this browser to open .onions. You could do so using Firefox if you wanted to, we have a guide for that, but you could just open the .onion in the Tor Browser instead.
As you’ve seen, there’s no LAN interface for Robosats. You need Tor.
