After I did all the updates today, my bitcoin knots health check now says “RPC stdout maxBuffer length exceeded”. I believe this happens once I connect at least 4 of the services to it. No idea how to fix.
I am on the latest 0.4.0 beta
I got the same thing on core 31.0:8, also on the latest 0.4.0-beta.6. If I turn off mempool (3.3.1:1) and fulcrum (2.1.0:9) and restart core, it goes away. I can restart fulcrum and it’s fine, but if I try to restart mempool it comes back.
Make sure you are running the latest Beta 6 version of StartOS 040 as well as having all services up to their latest versions.
Everything is as updated as it can be.
mine as well. that is what caused the issue
Hey, same here .) Im on beta 7 with bitcoin core, all services updated. I can see xx lines of “Health Check bitcoind failed: stdout maxBuffer lenght exceeded” in my logs and after some time it goes back to normal. But it looks like just health check issue, because it keeps its peers connected and overall looks like running just fine.
mempool appears to be the trigger that causes this issue
Updated to beta.7. Still have issue.
same. still happens even when i leave mempool stopped as well
trying to use my core node alone with only bitcoin and tor running causes the same issue
Make 100% sure that you are on the latest versions of StartOS and also all services by hard refreshing the “Updates” page (Ctrl + Shift + R) (CMD + Shift + R on MacOS).
Once everything is on the latest version, this is no longer happening.
I’m pretty sure it keeps happening ![]()
Updates for those services are currently in Alpha testing stage and will be released shortly to the main Start9 registry.
These new versions fix the issue.
I have the same issue after upgrading to 0.4.0-beta.7. Updated all services. Health Check bitcoind failed: stdout maxBuffer length exceeded. bitcoin knots 29:3:5 edit: When I stop mempool service there is no issue.
i believe this is now fixed
yes, looks like its fixed ![]()
