Hi,
I’ve been wanting to run a Tor relay/bridge, is this possible on Start9? Could it be done through Webtop or SSH?
Thanks fellers
Hi,
Thanks fellers
What exactly are you looking to do precisely? There’s a huge difference to what is available/supported and what is “possible”. Unless you’re looking get your hands dirty under the hood yourself, then the most accurate answer is probably “no”.
I don’t want be messing around too much under the hood, don’t want to break anything. Much chance of this coming as a feature in the future?
Definitely possible that this becomes available. Not sure how likely.
There are many services that have been packaged for StartOS. If you want to be able to just run Tor relay/bridge as a service, we will need someone to package it first.
https://startos.fans/ is an unofficial location where people have posted their requests for services to be packaged. You can upvote Tor Relay Node there.
There is now a TOR service for StartOS v0.4.0. Check it out.
