Hi everyone,
I’m running Start9 on a VM hosted on Proxmox, and the Start9 server’s traffic is routed through another VM that acts as a VPN gateway (using Windscribe). The setup works perfectly when I make network, DNS, and routing changes, but all these changes are lost whenever the Start9 server reboots.
My Setup
- Host Environment: Proxmox.
- VPN Gateway: A separate VM running Windscribe VPN with IP forwarding and NAT configured.
- Start9 VM: The Start9 server routes traffic through the VPN gateway via a static route.
Changes I’ve Made
1. DNS Configuration:
- Manually set DNS servers to
9.9.9.9and149.112.112.112. - Used
nmclicommands:sudo nmcli connection modify "Wired connection 1" ipv4.dns "9.9.9.9,149.112.112.112" sudo nmcli connection modify "Wired connection 1" ipv4.ignore-auto-dns yes - Created a manual
/etc/resolv.conffile:echo -e "nameserver 9.9.9.9\nnameserver 149.112.112.112" | sudo tee /etc/resolv.conf - Disabled and masked
systemd-resolvedto prevent it from managing DNS:sudo systemctl disable --now systemd-resolved sudo systemctl mask systemd-resolved - Verified
/etc/resolv.confcontents to confirm the correct nameservers were set.
2. IP Routing:
- Modified the IP routing table to route traffic from Start9 through the VPN gateway.
- Configured a static default route:
sudo ip route add default via 192.168.0.191 dev ens18 - Ensured the Start9 server could ping the VPN gateway and external DNS servers.
3. NetworkManager Settings:
- Modified the “Wired connection 1” configuration via
nmcli:- Enabled manual IP configuration for DNS.
- Disabled auto-configured DNS by setting
ipv4.ignore-auto-dnstoyes.
- Ensured the connection was brought up with:
sudo nmcli connection up "Wired connection 1"
The Problem
After rebooting the Start9 server:
systemd-resolvedService:- Despite disabling and masking
systemd-resolved, it re-enables itself on reboot, resetting DNS settings. - The
/etc/resolv.conffile reverts to a symlink pointing to/run/systemd/resolve/stub-resolv.conf.
Routing Table:
- The IP routes added via
ip routeare lost on reboot.
NetworkManager Changes:
- The changes to “Wired connection 1” (manual DNS and ignoring auto-DNS) do not persist.
What Works
- The Windscribe VPN gateway remains unaffected by reboots. All NAT and forwarding rules persist correctly.
- When I manually reapply all the above changes after a reboot, everything works perfectly. The Start9 server connects through the VPN, DNS resolves properly, and Tor circuits are established.
Questions
- How can I make these changes persist on the Start9 server after a reboot?
- Could the Start9 server’s environment or EmbassyOS be interfering with system-level configurations like
resolv.confand routing? - Are there additional configurations I need to apply to ensure
systemd-resolvedstays disabled and routing is preserved?
Any advice or suggestions would be greatly appreciated! Thanks in advance!
