Sideload jam 0.4.1?
getting this error when attempting to start jam 0.4.1 through sideload.
jmclient.jsonrpc.JsonRpcError: {‘code’: -18, ‘message’: “Wallet file verification failed. Failed to load database path ‘/root/.bitcoin/embassy_jam_wallet’. Path does not exist.”}
S9 ui shows jam api is unreachable
There are issues with this version and you should wait for re-release on the marketplace with v0.4.1~1
Would you like to try Jam v0.4.1 from the beta marketplace? In theory it’s fixed – let us know how it goes if you try it.
If you need to add the beta registry to get it you can do that by Marketplace > Change (middle of the page) > Add custom registry > https://beta-registry.start9.com/ > Save and connect
