SOLVED Database error no rows returned recovering from existing data drive
Running Start9 in a VM in Proxmox with 2TB passthrough SSD as data drive. All good.
Had to reinstall Proxmox then recreated the VM, installed fresh Start9 (same version - 0.3.5.1).
Chose recover from existing data disk selecting passthrough SSD.
Starts to initialise then reports error:
RPC Error: Database Error no rows returned by a query that expected to return at least one row
Can’t ssh into VM because Start9 hasn’t enabled ssh yet.
Any ideas how to diagnose/fix?
I had attached the data partition instead of the whole disk.
Thanks for the update. I’m sure you’re not the only one who has made, or will make this mistake in Proxmox. Maybe this will save them some time/pain.
