Hi,
I am having trouble connecting Sparrow Wallet on a Macbook to my Start9 server using Electrs. I have done the following:
- Completed blockchain download
- Completed electrs indexing
- Trusted CA on my Macbook
- Inserted the RPC Hostname in the Properties tab of electrs into the Sparrow Server tab and selected Electrum Server to connect to.
- Inserted port 50001 into the same Sparrow Server page.
My preference would be to connect via only the LAN and not have to go through TOR, so I have tried to change the Hostname suffix to .local instead of .onion. However, that connection failed. I also tried the .onion suffix, and that failed as well.
First, I am wondering if it is possible to connect only via the LAN without using TOR, and if so, what is the right way to do that? I could not find any guides about that online. Second, if I do have to use TOR, what other troubleshooting steps can I take to make it work? Thank you in advance.
