Specter not installing
having an issue installing the new version of specter on my start9 setup, getting a failure to install error
specter - Install Failed
Install of specter@2.0.2.2 Failed: Filesystem I/O Error: request or response body error: error reading a body from connection: error:0A000119:SSL routines:ssl3_get_record:decryption failed or bad record mac:ssl/record/ssl3_record.c:622:
Hi @Red1230, Thanks for reaching out. This could be a network issue having to do with connecting to the community registry. I would recommend starting with a “hard refresh,” in case you haven’t done so yet. Try hitting CTRL+SHIFT+R (or Cmd+Shift+R on macOS) when visiting the community registry page to hard refresh it and let us know if that helps.
