Start 9 not booting after incorrect shutdown
Hi all,
We had a power outage and my server shutdown (I use start9 on a mini PC). Since then it will not boot and I get the errors listed in the image attached.
If I boot in recovery mode I have no trouble and can use the server as normal.
Any idea how I rectify this?
Thanks guys
You should really use a UPS to prevent disk corruption.
For now we’d reinstall StartOS and hope everything is where you left it.
First you’d create the bootable USB, boot it and select the options to keep the existing data:
Then you install StartOS, selected to use the existing data partition:
https://docs.start9.com/0.3.5.x/misc-guides/attach-drive
If at any of these points no drives are detected… then your partitions are gone. And you’ll have to recover from backups.
