Hello, I’m trying to get help with my LND node where I have a channel stuck in pending. The person trying to help me on the LND side said I should manually connect to the peer but the command the gave me just returns -bash: lncli: command not found how do I control LND from the command line so I can enter teh command?
If it helps I am trying to run the lncli command
Keep in mind that this is considered an advanced feature that should be used with caution and you should know what you are doing since you will responsible for any damage that happens.
Since you mentioned in your question that you are a beginner user, this might not be the best option.
If you want to continue down this path with the guidance of the LND team, you can access Service Containers to enter commands by following this guide from our documentation.
