Dear Engineer,
is it possible to have 1 bitcoin knots node server and be able to connect to own host public pool server + datum ocean server at once ?
try to install public pool + datum run then at once but they all do not show metric
delete the datum and the public pool metric came back hashing.
if it is possible can show how to do it that would be awesome to have 1 node 1 running own public pool for solo lottery and 1 running datum ocean for a fix mining.
Regards
Shen
Public Pool and Datum can both be installed on the same server. The issue is, until the next version of StartOS, simpleproxy is needed. But again, that can run with multiple services. They happen to use different ports. 3333 vs 23334 I think.
Neither of these needs more than 1 Bitcoin Knots instance, multiple services can depend on Bitcoin Knots.
Dear Pebs,
by installing datum config on other side the public pool stop working no metric is shown, after deleting the datum on the start9 pure the public pool start showing metric again like normal, would be awesome if it is possible to link public pool self host for bitaxe and rig on datum ocean for earning permanent sats.
Regards
Shen
