Hey folks
I’ve noticed, according to my RTL instance, that the S9 node no longer accepts channel opens less than 0.16777215 Btc. The channel I had open was closed recently. Seems an awfully high minimum change!?
Hey folks
Hi @Subversion, did you actually attempt an open and get rejected with that number, or is this a value you’re reading off some settings/limits display in RTL?
As a quick follow-up, I’m being told that the channels were closed, and people shouldn’t open channels until further notice.
cc: @StuPleb
Yes it was a failed open that reported that figure. Thanks for the heads up, hopefully it’ll be back on song soon![]()
Any updates on your lightning node folks?
Good morning. I’ve managed to enter my password to CLN but now tells me I cannot connect to the node. I did have a channel open but was unable to access for a while.
