Hi all,
My Start9 Pure has been completely offline for approximately 48 hours after saving the Bitcoin Knots 29.3.1 configuration. I’m hoping someone has seen this and can point me toward a recovery path.
What happened:
I received the Bitcoin Knots 29.3.1 update notification. The install initially failed with the error: ‘Install of bitcoind@29.3.1 Failed: Config Generation Error: No Match: consensusrules: Field Is Not Nullable’
The service showed ‘Needs Config’. I opened Config, saw the new ‘Consensus Rules (New)’ field pre-populated with ‘rdts’, verified my Tor-only settings (Disable Clearnet ON, V2 P2P Transport ON) were intact, and hit Save.
Knots showed ‘Stopping this may take a while…’ — and then all services went to ‘Unknown’. Shortly after the web UI became unreachable entirely.
Current state:
- No ping response to
10.0.10.225 - SSH times out (
ssh start9@10.0.10.225— ERR_CONNECTION_TIMED_OUT) - Web UI unreachable at both
https://10.0.10.225andhttp://start.local - No display signal on HDMI (tried multiple ports, monitor confirmed working)
- No audio from the unit (no Beethoven’s 5th / Diagnostic Mode audio)
- Solid white power LED — unit is powered
- Multiple power cycles performed including leaving overnight — no change
What I’ve tried:
- Hard power cycle (unplug, 60 seconds, replug) — multiple times
- Left overnight after power cycle — no change
- Tried
http://start.local— timeout - Tried direct IP via HTTP and HTTPS — both timeout
- Connected monitor before power-on across all HDMI ports — no display signal at any point including POST/BIOS
- SSH attempt — connection timeout
Hardware:
- Start9 Pure (exact model/year uncertain — trying to confirm)
- Connected via ethernet to LAN, static IP
10.0.10.225 - On UPS
What I have ready:
- Ubuntu 24.04 LTS live USB prepared via Balena Etcher on a 64GB Kingston DataTraveler
- Willing to attempt USB boot recovery
Primary questions:
- Has anyone else had the Start9 Pure go completely unresponsive (no ping, no display, no SSH) after the 29.3.1 Knots config save? Is this a known issue?
- What is the correct boot menu key for the Start9 Pure to attempt a USB live boot?
- Is there a known recovery procedure for this specific failure mode?
- Any way to confirm whether the OS or the data partition is the problem?
My main concern is preserving the data on the drive (full Bitcoin blockchain, Gitea, Vaultwarden). I am not looking to wipe and reinstall unless absolutely necessary.
Any help appreciated. Thank you.
