My server is running StartOS 0.4.0.4. Today, 3 November, I downloaded the update to 0.4.1.1 and clicked Restart to apply it.
The interface has remained on “Restarting” for over an hour. Opening a new tab and doing a hard refresh haven’t cleared it. Clicking “Restart to apply” again has no effect.
All installed services appear to be running normally.
OS logs repeatedly show:
receiver dropped
shared-libs/crates/start-core/src/shutdown.rs:144
There are also “Error in db websocket” / “broken pipe” messages.
I have attached the OS logs and screenshots. I haven’t disconnected power or forced a shutdown.
What is the recommended safe way to restart the server and complete the update when the web restart control isn’t working?
Your restart is probably stuck waiting for one of your services to finish stopping. That service never does, so the restart waits forever. It’s a known issue and we’re working on a fix. Your data is fine, and so is the update: 0.4.1.1 is already in place and takes over the next time the server boots.
The safe way out is a normal power-off:
Press the server’s power button once, briefly, without holding it. That’s a clean shutdown, not a power cut. It can take a couple of minutes to go dark.
Once it’s off, press the button again to start it.
If you use SSH, sudo reboot does the same thing, better.
If it comes back on a red Diagnostic Mode screen with Multiple Errors, click Restart server, not Repair drive. That’s the same stuck shutdown failing on the way down, and a second restart clears it.
The receiver dropped lines are from your extra clicks on Restart: the server turning down a new restart while the first one is still going. The “Error in db websocket” and “broken pipe” lines are the dashboard’s live connection dropping, probably each time a tab closed or refreshed. Neither is a separate problem.
Until the fix ships, the restart for the next OS update can get stuck the same way. If it does, same steps.
